No Spark?
89sport
OK so early last week I started up my truck and backed out 2 feet of my driveway and it died. Wouldn't start so I did my basic checks and the Alternator was dead, so I replaced it. Also tested the battery and starter both were good. After all that I wasn't getting a spark so I checked the DIS and it failed so I replaced that, I did get all 3 bolts back in(even though the instructions that came with it said put all 4 in????) it did only have 3 and only 3 holes in the mounting bracket. And still it will not start. I did pull the connector out of both coil packs separate times to see if one was bad but it still didn't do anything.
My only guess is the crankshaft sensor. How do you test it? I would check my repair manual on how to but its 2 hours away.
thanks in advance
