bluedanger
Hey all, I'm about ready to lose my mind over here. I have an 88 2.9 5speed. The problem started about a month before it went out for good but it would at times just stall out then be a real pita to start back up. Most of the times when its a cold start she would pop rite off, drive awesome then act like it was missing and losing fuel, 2 minutes later it would be normal again. Since then I have replaced fuel pump, tfi module, pick up coil, checked about every ground, checked continuitys and still have no spark and no fuel pump kicking in. Off of the coil wire when checking the spark you see one tiny weak spark after you stop cranking it over. Another thing is that the voltage at the fuel pump terminal with key at run will just bounce between 0.5 to about 10 volts never holding at a constant voltage. I'm starting to believe maybe the computers shot because in unplugged it just to see what would happen and i had normal spark again, but obviously no fuel. PLEASE HELP!
