magnum2
- Sep 14, 2009
My 1994 2.3 5 speed manual just died out of the blue with no spark leaving me stranded 70 miles fron home. Any ideas?
A little history on the truck.
I bought it off a girl i know who wanted to sell it because the clutch was shot and she had bought a new truck. It is real clean with 90000 on it and is all original.It ran fine and smooth when i bought it just seemed like it needed a tuneup.
Well i put a new clutch and flywheel and pressue plate in it and at the same time went a head and put a new timing belt and waterpump and all new hoses and a idler and belt on it so i had nothing to worry about for a while.
I also replaced all the plugs on the passenger side and replaced the wires on that side only as the other side is a bitch. The plugs were most likely original.
Well the truck was still dogging but ran smooth so i assumed the cat was plugged.I drove it for 5000 miles like this and it ran fine just seemed like a dog.I used to own a 2.3 Pinto back in the 70s and it didn't even have the header or injection and it was much more livelyer than this 2.3 .
Well after 5000 miles it started running really chity to the point it was undrivable.So i go great i had just parked my clean 1990 Bronco because after a month of trying to figure out why it is running like chit i gave up and went back to my clean Ranger and it is pulling the same crap.
So i pulled the manifold off and cleaned and inspected all the injectors and cleaned all the plugs and used the electrical silicone on them. Cleaned and electricaled siliconed all the sensors and plugs .
Put new spark plugs and wires and put a ton of seperating clips on the wires to isolate them from each other. Also dismounted the coils and cleaned the bases and reassembled.
Started it up and it ran like a champ. Smooth as can be.
Took to go out of town today and during some rain it just started dying. I turned the key on and off and it would reignite and go and than die again till i ended up on the side of the road.
Tested for spark and had none. Checked all connectors and grounds still no spark.
Had the GF drive 70 miles to get me with a new ignition module and ignition switch. Neither of them made a difference still no spark.
Whats left ? The crank sensor the cam sensor and the EEC ?
How often do the crank or cam sensor fail and how hard is it to put them on? Is ther a test to check the sensors and can Autozone test the EEC Also.
I have a Haynes manual but i don't see where they mention install and checks on them.
Any help would be appreciated. Sorry for the long story but i just wanted to give everybody the whole heads up on the condition of the truck
And like i said about my Bronco on FSB --God i miss a carburator and a normal distributor.Not to many things to go wrong.
Thanks for any help. Great site by the way.
