Dfw_ie
- Oct 9, 2012
- Automatic
Hello, I have a 92 3.0L ranger, I am not getting spark at
the coil. The coil and the Ignition Control Module are new. The ignition coil has two wires connecting to it (red/light blue and tan/yellow) these same wires are also connected to the ignition control module through the factory harness. I bypassed the harness and connected the tan/yellow wire directly from the ignition control module to the ignition coil and the truck would start when it was turned over. I did a continuity check to ensure that the wires are not faulty through the wiring harness and they seem ok. Does anyone know what could be preventing the ignition control module and ignition coil from communicating? In my mind I would think that there is something between the coil and module that is preventing the signal. Any help is appreciated.
