Positive P
- May 13, 2013
- Age
- 50
I bought a '94 Ranger for a work truck. Not knowing that it would become my only transportation.
Ran fine for over a year, minor things here and there,
Pull up to a stop sign recently and BAMM, starts running rough and stalls out.
Try to restart, and it just turns over and backfires A LOT.
Thinking okay, may have only jumped time. I have it towed to the shop and tear it down.
Now I bought this truck without the timing cover, I followed some internet advice and pulled the timing up on #1. Crankshaft key is in the 90 degree position and roll pin is almost in a straight line with the crank position sensor. Now, The camshaft however has a mark beneath it and it was slightly off with the crank in this position.
Thinking this is it, I buy a new timing belt, remove everything including the sensor, and replace the belt.
Align the crank sensor back up with the provided tool that comes with a new one. I replaced it while it was apart, as routine maintenance.
Try to start it to see how things are and runs the same, turns over but only backfires. Thinking some idiot in the shop touched something they shouldn't have, I recheck the timing and still dead on. So I try 180 degrees to see if that was it. Align the cam up on it's mark and loosen the belt, turn the crank over by hand till it lands on it's mark again. Try again and backfire.
So that's where I'm at. Work on it in my spare time, been three weeks, this truck is my only transportation and I'm sick of walking.
Any help please.
Any help please.
