- Jun 2, 2009
- Wisconsin
- Total Drop
- 3"/4"
How does the Fuel pressure behave on your ranger under boost? When i get above 2-3lbs the pressure is all over the board. I had a feeling this was the case since the motor seemed way under powered. it makes boost but i dont feel any pull. i can see the pressure increasing but the power seems done. If you are running the stock regulator do you have to change out the pump. I have both the stock pumps running now but i was wondering if i should remove the in-line pump and run a walboro in-tank pump and increase the flow. Also do you run the stock fuel filter, or did you upgrade to a less restrictive one? I finally got my bov to work but now i am finding out that the a/f mixture is leaning way out under boost. Has anyone made/bought an adapter to replace the stock fpr with an aftermarket one and still use the stock fuel rail?
