Ok. Since the connector to the a/c control usually plugs in and locks in by snaps, (acording to online searches) I'm sure there should be no reason for it to come unplugged. Everything else still works. No blown fuses, relays in outside fuse box have been tested and no problems. I am basically seeking information as to why it would just suddenly have no power. Do you have any other suggestions? Could it actually be the off/on switch itself? Is that a normal failure over time? The vehicle is never abused, the dash has never been diassembled for any reason. Everything on the dash panel works as normal as day one except, the a/c mode on the switch. Neither a/c or Max a/c works. Blows air through the proper vents, everything but feed power out to the system. Switch on the contol panel bad? I tested the relay, it's good and has good resistance of around .73, minute resistance across 30 to 87 poles with 12v applied and good voltage, opens and closes. Tested fuse and fuse socket, there is power there . There is no power at the low pressure switch, the high pressure switch or the compressor.
