Howdy Yall,
I picked up a Fully Loaded new for 89 Ranger supercab 4x4 that had a blown motor for $Free.99. It was my plan to take the motor, That runs amazed, out of my recently rolled base model 89 and swap it in, clean it up and make it my new daily driver. So I pulled the motor and figured I would do a budget rebuild. Long story short, blown motor had brand new top end so minus the cam I swapped it to my rebuilt motor.
I get it all in the truck and run it...no power as in a 2.3 would out run it more than likely. When I floor the truck I get a lot of noise from the intake and the motor eventually revs to the redline and shifts, 4 high or 4 low, doesn't matter. I double check the timing and it's correct, adjusted the valves again, still no joy. Fuel pressure showed solid 40 psi at idle and WOT. 100 psi from the comp test, pulled the motor and found a few rings to be out of position so I bought new rings and was overly careful putting it all back together. Cam is timed so that the crank gear is at 12 and the cam gear is at 6 (dots together in the middle). Button it all back up, put the balancer on and notice that it isn't sitting at 0, just slightly off a few degrees. But the cam is timed so I figure I can compensate with a twist of the distributor.
Motor back in the truck, compression is the same, mind you I didn't bore the block, just a good hone. still no power, no matter where the distributor is so I put it back to 10 BTDC with the spout unplugged. No cats, tried losing the muffler to see if that helped My friends and I are baffled on this one. I've built quite a few motors and never had something like this happen.
Any help is appreciated.
