ASE Doc
- Nov 18, 2016
- Automatic
Hi Everyone, I'm new to the forum and come begging for help from the Cologne engine builders. I'm an old mechanic who is trying to help a friend restore his 78 Pinto Runabout. The engine has been freshly rebuilt. How we got to this point is a long story, so I'll cut to the meat of it. Before sending the motor to the machine shop, I found the LH valve train had been running dry. I traced the lack of oil to what looked like a worn #3 cam bearing. I was getting plenty of oil to the RH side, but little or none to the LH. I blew air down through the oil passage and could see the air coming out around the bearing.
I made sure to tell the machine shop about the oiling problem so that they could make sure it was resolved in the rebuild. Now the motor's back in the car, still no oil to the LH rocker shaft. I was talking to a friend over on the hotrodders forum who is building a 2.9, he referred me here for more information. He also mentioned something about an updated #3 cam bearing that Ford had released that was intended to solve the rocker oiling issue.
There should be a TSB from Ford presenting the upgraded bearing and recommending it to replace the factory installed part. Has anyone heard of this? If there is a different bearing, I want to be sure that my machinist knows about it before he goes back into this thing. Experience tells me that if Ford had redesigned the bearing, the aftermarket would have picked up the redesign and it should be standard in any bearing kit. I just want to be sure. 2 times out and in with this engine is plenty for me.
Thank in advance for any help.
