Roadhog
Does anybody know where i can find something that will show how the oil flows through a 2.8. I just rebuilt this engine, drove it 60 miles and decided to readjust the valves again as they were getting pretty noisy. I did the drivers side first. Everything looked normal and only 1 of the valves was slightly out of adjustment. When i pulled the valve cover on the pass. side everything was bone dry. still had lubriplate on the wear points but no oil. I went as far as pulling the rh rocker shaft and starting the engine [ran pretty good on only 3 cyl. i was surprized] No oil coming from the delivery port in the head. Now what? I think iam going to pull the head off and verifiy that the oil port in the head is not plugged. I did blow some air through the oil hole with a rubber tipped blow gun. Iam not sure where the air went but it was flowing and oil came out of the rockers on the drivers side while i was blowing air into the pass. side. I also tried running the engine again with the rh rocker shaft off after i blew the air just to see if i unplugged it, if it had been plugged. still no oil.
