88mudder
- Aug 26, 2007
- Age
- 36
- waterford michigan
the first question i would ask, is how many miles are on the motor? myself, the first thing i would check with minimal valve movement would be the cam lobes [ i know, PITA, cuz you have to tear upper end down] then i would check valve spring pressure, i have heard it done, not sure what is needed for test, and actually you could do that before pulling the cam. as for the oil no flow, if you have had the distributor out of the motor, i would check to make sure that the intermediate shaft that drives the oil pump is fully engaged in the distributor AND the pump, could be that if you had the distributor out for any reason the shaft may have fallen into the pan [ another PITA] but you may be able to verify if you have enough room to drop the pan a little bit.Well the whole reason why my 302 dont have power is because i have 0 oil pressure. The valvetrain is noisy as hell and the valves are barely moving, and no oil is coming up the motor when i took the valve covers off and let it run. Any tips on what to do next?
the first question i would ask, is how many miles are on the motor? myself, the first thing i would check with minimal valve movement would be the cam lobes [ i know, PITA, cuz you have to tear upper end down] then i would check valve spring pressure, i have heard it done, not sure what is needed for test, and actually you could do that before pulling the cam. as for the oil no flow, if you have had the distributor out of the motor, i would check to make sure that the intermediate shaft that drives the oil pump is fully engaged in the distributor AND the pump, could be that if you had the distributor out for any reason the shaft may have fallen into the pan [ another PITA] but you may be able to verify if you have enough room to drop the pan a little bit.sorry i couldn't have better scenario for you.
Looks like you're heading the right direction.unknown mileage on the engine, i bought it used from a dishonest guy. Im going to pull the motor and put in on my stand and tear is apart from there... ...Any tips on what to do next?
I would say time for a rebuild.
Hey mudder how far up is waterford mi.?
-Check the pickup screen
-Might replace the pump (unknown mileage) then you'll know! Whether you use a stock, or a higher pressure/volume pump depends upon your build. A general rule of thumb I've learned is 10 psi for every 1000 rpm of operation. i.e.- 6000 rpm = 60 psi. A good OEM stock pump is usually sufficient.
-Might replace the dist. drive shaft w/ an upgrade (larger diameter)
-Seeing as how you're pulling it apart, do you plan on pulling the oil plugs out of the gallery and "rodding" it? -Dip the block?
Just some thing to consider. Honestly!
Considering the economy --Im not sure... ...the whole thing will be costly...
Sounds reasonable and $$ conscious.Im going to replace the pump while i have the pan off... This engine never had a engine oil dipstick... ...Im thinking the lifters might be collapsed or clogged... ...a cam and lifter set... ... 289 heads...
Is this a good plan?
