snatiep
- May 16, 2010
Hello Everyone,
This morning I noticed my headlights were not working, neither the low beams or the high beams.
The side marker lights, turn signals, brake lights, all work fine. It's just the low and high beam headlights that aren't.
I took off the fuse cover from the left side of the dash inside the cab and all of the headlight fuses are good.
I opened the fuse box in the engine compartment and the one headlight fuse is also good.
I used a meter to check all fuses.
I also have 12v power at all of the headlight fuse sockets, both inside the cab fusebox and in the engine compartment when I have the main headlight switch turned on.
I removed both headlight bulbs and there is not 12v power at either.
Do you think it could be the multifunction (turn signal) switch?
A few times in the past couple of weeks when I would turn on the right hand turn signal, it would click really fast until I cancelled the signal and re-apply it then it would be fine. Also sometimes when I would push in on the windshield washer button it wouldn't work unless I pushed in pretty hard on it.
I'm at a loss of where to check next and would be very grateful for your help?
