It has the right fuses, its been stock and unmolested until yesterday that the lights quit working
seems like the extra load of the relay coils sint that big to make the switch burn the fuse, but idk. maybe thats the reason, ill try to take it to an electrician tomorrow.
I was hoping that the painter would have my moms truck ready today, but he didintslowass painter. Now i cant do work that requires mine to be out of comission because we dont have the other truck.
Weird thing is: the running lamps work fine, its just the head lights that wont work.
Not even the high beam light on the dash will work, at first i had highs if i pulled the lever(wipers/light change) but when i removed the rests of the fuse, they were all goneare your light bulbs dual filament? maybe you just blew half the light?
I'm looking at a wiring diagram for your truck and there seems to be two fuses numbered 4 & 8 inside the cab for both low beams on the headlights. Did you check those to see if the were both blown?
Yeah, ill check both. The wipers work fine.
Idk if the same fuse works for both switches tho.
Headlights are for panzies.
