fivespeed3.0
I've got a 2000 Ranger 4X4 3.0 5 speed flex fuel. Yesterday I changed the oil and noticed the battery terminals were corroded so I cleaned both, removing the negative terminal first then the positive, replacing in opposite order, ie, pos first, then negative. When done, I took a ride to a friend's house, about 20 miles, and several times along the way, both the 4WD High and 4WD Low lights would flash about six times simultaneously. I got to my friends house ok. No lights flashed on my way home. Was this just the computer resetting after having the battery disconnected, or should I be concerned? I replaced the battery twice before and this never happened. Any help would be greatly appreciated!!
Thanks
Thanks
