No fluid to the rear brakes.
itsjay70
Hi guys and maybe gals
I've been lurking on this site for awhile and its saved me hundreds of dollars in repairs i've done myself (thank you) but i have another issue i can't seem to figure out.
I have a 2000 Ranger 4x4 with ABS. Unfortunately my rear brakes aren't working. After my 40 minute commute to work i decided to touch the rear drums and they were ice cold to the touch. Later i did a test on ice and with my foot on the brakes my rear tire were spinning in drive. About a year ago (10K miles) the pads and cylinders were replaced.. I tried to bleed the rear brakes last night and I just couldn't get the fluid flowing..Since i have 4 wheel ABS i don't have a proportioning valve (i was told that actually). Where should I look and where would there be a block?
First place I'd suggest is at the T on the rear axle.
Disconnect there and see if flow is getting TO the T (splitter).
I also suggest using a penetrating oil and it's worth buying a flarenut wrench set, if you don't already have them.
Those fittings tend to round off if you don't.
I suspect the rubber hose that feeds that T has clogged, so check the forward end of it too.
And Welcome to The Ranger Station!
I did just what you suggested and it worked. I took off the T connector with the hose and blew air through it. I reinstalled it and bled the brakes. Now I have rear brakes.. If the problem reoccurs I will just replace the hose next time.. Thank you very much. This is a great forum!
Sometimes the flex hoses (front too) break down internally and act like a check valve, blocking flow. I'd replace that one.
