mixwell
Hey my 2001 3.0 ranger recently has no power at all when I went out to start it so I disconnected the battery for a few minutes and reconnected it and the dome light works and I have juice until I go to crank it all the power is killed again.
The posts are clean and there is no corrosion around the terminals, I had my friend check it out and use his volt meter but he couldn't find out specifically what is causing this issue. Has anyone had this similar situation or any input ?
Thank you
Thank you
