indyranger
- Dec 24, 2007
- Age
- 68
- Automatic
About a month ago I had the first opportunity to use my heater, low and behold no heat. About a month previous I changed out the t-stat, this is on my 08 XL 2WD, 2.3DOHC, I thought possibly I did something under the hood, maybe to the hot water control valve, nope it was fine. After checking here for info I began to look into the blend door issue. I removed the blend door actuator and the door was moving smooth and easy. The truck has only 25,000 on it and just 4 years, I was glad the door seemed to be fine. I checked into the actuator, found a test procedure provided by another member and it tested bad. Purchased a new actuator from my Ford dealer after seeing warnings about using the after market variety. Installed it today and I now have control again. If you are reading this and are searching for an answer to a similar situation, you are definitely on the right track with this website. If you, reading this have posted info on this situation, thanks, I really appreciate this site.
