I have a pressure gauge attached to the fuel rail, and it's a pretty constant, 30-40 psi and after shutting off it will eventually go back to zero. Just guessing that it's running rich since the pump is always running, but it seems to run and idle ok. I had it at a service shop and since they couldn't get any codes, they basicly said they couldn't do anything, and he asked if the pump ran all the time like that like it wasn't supposed to do that, so I'm back to guessing. Even when it's warm it takes several seconds of cranking to get it to start, but seems to idle ok. I had driven it one time for about 3 hours, and it was like not very much power, I stopped for gas, and when I went to start it, it pumped out enough white smoke to look like it exploded, had to crank it a ton but once it started the smoke went away and ran, just not so much power. I'll continue to search for a leak.
