no 4x4 low
93 4x4
Solid Axle Swap
florida
Having a problem when I push the bottom I can get 4 hi push 4 low nothing happens check the fusses all look good,the shift motor is one year old. whats up.I think I know what my next swap will be! Why would ford use these pos's! thanks
Neutral then 4x4 low?
yep, the light doesn't come on nothing happens are there different fuse's or relay's? changed out the dash switch same thing
Isn't 4x4 fuse in the engine bay?
Sounds like it might be your control module if you dont hear a click from it (it's in behind the driver side booster seat ) You might also want to swap out the switch itself. They go bad, but not very often.
yeh, one single click when I push 4x4 low I'd hate to buy another motor and find out thats not it
I'll reiterate. Did you check your control module? (that's NOT the switch or the motor) Its a completely different part
