Yup, the two most common causes are the vacuum front hubs failing to do what they are supposed to is usually either the hubs themselves or the vacuum system for it. Seals, lines, etc.
I have seen the metal tubes that connect the vacuum line to the knuckle rot to where they leaked, dad’s 99 did that and since he was unwilling to change things, I popped the plug out and removed the remains of the tube, then replaced it with stainless tube.
Somewhere around 2000 they ditched the hubs and went to a “live” front axle with no hubs. To swap that in requires the CV axle shafts and wheel bearings from a 00-11 Ranger and to cap off the vacuum system.
