No 4 lo
1993Ranger4x4
Ford Technician
Firefighter
EMT / Paramedic
Hartford, CT
1993 Ranger 3.0 5 Speed 4x4 Push Button Transfer Case
4x4 Hi No problems
4 LO Nothing. Yes Its in neutral. Yes my foot is on the clutch, and yes, the parking brake is engaged.
Motor need service? Bad Fuse?
Let me know what you think.
Thanks
thinkin maybe your shift motor is dirty, the switch is bad or your module is going out. There is a self test writeup in the tech library as well as a 20 minute clean writeup for the shift motor. I would get a switch panel from a junk ranger (maybe 2 or 3) and swap them out to test it, and check your connection for anything impeding current.
I know Its not the wwitch, The switch is out of a vehcile thay worked well. Im guessing its the motor.
Parking brake doesn't matter. The service brake is the one that matters. Clutch and service brake pedal pushed down.
