CalgaryRanger
- Mar 8, 2011
- Automatic
Just bought a 93 ranger. Not sure if it is going into overdrive or not. At 60mph i am reving at 2500 rpm with 235's for tire. It seems to shift 1-2-d-od but if I pull it from OD back into D the rpms do not rise. The last shift only drops the rpm about 300rpm (could this be torque lock-up) or how much should torque lock up drop the rpm and how much should over drive drop the rpm.Is there a special way to verify tc lock up and od. Also it doesn't like to shift in D on a cold morning but if I put it manually into 2 then it shifts and after that it is fine. It seems like my shifting is out of whack. I have never owned an auto before and now I am starting to know why.
