SCREWd2V
- Dec 4, 2009
- Automatic
hey guys! as some of ya'll may know i did pick up the 1990 Ranger STX 4x4 4.0 this weekend!
the tires were dry rotted, so i drove it to a local town to replace with some cheapo used tires b/c i didn't really have the money for new, and i might be upgrading the tires to a larger size in the future.
it was pulling to the right on the 4 hour trip home. thought maybe it was an alignment issue. brought it to a buddy's shop for alignment. he thought it was a tire pull b/c worn tires. he was correct, before he could even begin the alignment, he lifted the vehicle, and found that the front tires were loose wabbley (not too bad). he stated that i would probley only need to repack the bearings.
well i would perfer to do this job myself, but he mentioned i would have to take off the 4x4 assembley, and that sometimes requires a special socket.
is this true?
as far as for my tire issue, i'm going to try to swap the tires around, see if that will do a quick fix for now.
the pads need to be replaced in the front, as long as the rotors resufaced. needs a new belt, power steering is a bit noisey, and the horn doesn't work lol
is this true?
