salisbury1882
I just bought my new rig… http://www.therangerstation.com/forums/showthread.php?t=19366
And it has the rough country lift on it and I read in the tech library and found the note under the rough country that said: “TRS NOTE: Uses plate-style axle bracket extension (creates a clearance issue with the Dana35 axle housing not allowing full movement of the suspension, can damage the axle housing) “
Can anyone tell me if extended radius arms would held this problem, I noticed ever lift out there other than the Rough Country comes with the extended radius arms. Can I buy just an extended radius arm kit? I am also looking into the F250 shock towers, would they make any difference? What has anyone else done to improve in this basic lift? Thanx for any help!
