New Wheels. Baja 8 steelies. 15 x 10 with Cooper cobras mild stretch. Had to do some trimming on the wheel wells plan on adding some aftermarket fender flares. Finally coming together
Spec d smoke lens. Thank you btw.i love the wheels..so much attention and compliments. The ride is great. I went with a 60 sidewall. 245 60 r15 it still givesa good ride because it's not a low profile. The tire is rated for an 8 and 1/2 inch rim so it's slightly stretched and that was on purpose so that it would fit in the wheel well better for my front turn radius. Doesn't rub at all I did however have to shave the tops of the wheel wells and plan on putting aftermarket fender flares. I'll update and put pictures once they come in waiting on Amazon LOL. I'm also going to upgrade my shocks to belltech street performance. The rear does sag a little bit when I put in any type of weight so I plan on buying a set of heavy duty leaf springs it shouldn't change the ride height and when I load the bed with things or trailer it won't sag in any longer. Those leaves are 367000 Miles old. I'm about to have a 400k truck
For
