New U-joints Loose
jk10sport
Oklahoma City, OK
Didnt know where to post this so sorry if in the wrong section.
I have a bad vibration in the truck at high speed, so I decided to replace the u-joints today. well when I went to take the old u-joint off the front Flange (not the shaft), I took the out the snaprings and the u-joint just fell out, arent they supposed to be pressed in? the new u-joint just slides around inside the hole and im afraid to put it back to gether for fear my drive shaft will fall off on the road. all the rest i had to press in. Will it be okay if the snap rings are in?
No, they have to be tight (pressed in). Sounds like the flange piece is hosed on it.
Probably your cheapest option is to find another one in a salvage yard (I assume this is on your '03 Ranger and not the '10, otherwise warranty should cover you if it's your '10)
