Cmillzz83
Okay...so I think this is where I need to be asking a serious question about my 91 ranger sport,manual shift with the 4.0 liter engine...I have replaced the ignition lock cylinder,the ignition coil pack,the battery,the crank shaft sensor,the fuel pump and it is getting fuel pressure,and replaced the icm. The guy I got it from keeps saying something about the ecm computer and said that when he looked at it he saw corrosion in the board but I pulled it apart and the board is clean as a whistle and I'm getting no spark. There are a few questionable wires under the hood on the left side when facing the motor. They are both black with white stripes. One has a wide white stripe and the other has a thin white stripe. Not sure if those have anything to do with the issue but they are both cut and not connected and I don't know where they go. The ecm computer module does for some crazy reason have the date 2003 printed on it so I was wondering if it's possible he put a computer from a 2003 in it and it may have fit and that could be the reason for no spark or will the one from a 2003 not even fit a 1991? Please help I need to get this sucker running badddd lol. Thanks
