fireman660r
- Apr 21, 2009
- Automatic
Hey everyone. I bought a sandrail last week with a 2.3L turbo in it. I have some questions regarding the setup however. The exhaust manifold is a ford part as well as the intake, it also has a Motorcraft carb on it. The turbo is a garrett. I do not believe that this is a factory set up though. The turbo pushes air to the carb instead of pulling it through. I have been told that I should switch to a side-draft weber set-up, but don't know how. I am curious if the push through set-up would work good if it was set-up correctly. The waste-gate is wired open as of now, because the previous owner said that it ran crappy when the waste gate was closed. Any help with this would be greatly appreciated. Thanks
