new tires need help deciding
98Mazda4X4
ok im getting new tires before long and im kinda leaning torwards the wild country mtx in 31x10.50 but also considering a 32x11.50 any suggestions on tires or size i turned the t-bars on my truck for more room suggestion please
with cranked t-bars i would only do 31's so you dont have any rubbing issues unless you lift it more
32's fit just fine on my truck with slightly cranked t bars they only rubbed once from hitting the bottom of the driveway too hard. My 33's barely even rubbed at full lock
if i were you id get a set of p265/75/15, they're the same as thirty one's but tend to be easier on the wallet. If i were you id get the open country A/Ts siped, that's what i have on my truck, and i live in alaska and i don't slip at all in two wheel drive in the wintertime. Also the XTX's tend to wear quicker, i know this because i work at les schwab
