nEW SUBWOOFER DIFFERENT LOOK?
gertsdsbs
On the Moon
sO I HAVE A ONE 10 INCH KICKER SUBWOOFER SHALLOW MOUNT BUT WANT TO BUY ANOTHER. i NEED TO KNOW IF THEY ARE THE SAME THOUGH. i BOUGH THE ONE I HAVE 6 MONTHS AGO, ITS THIS ONE http://www.caraudiodeals.com/kicker-07cvt104-p-970.html
But now they look different like this one
http://www.amazon.com/Kicker-10Inch-Shallow-Mount-Subwoofer/dp/B0036MQWN8/?tag=959media-20
So my question are they the same although they look different? They have the same specs so is there anything i should worry about other than the color difference? What do u guys recommend? THANKS!!!!!!!!!!!!!!!!
if they seem like the same sub on paper, then there shouldn't be any problem besides aesthetics...
i would however note if they are slightly different at all, or even with the fact that one will be broken in and the other one isn't (if you're adding and not replacing the first sub) then it can and most likely will sound a bit different and they will look out of phase.
if all it comes down to is aesthetics then you are fine. i would shy away from putting different brands/specs in the same box however.
oh, and there is no need for all capital letters... it's 1) rather annoying to read and 2) usually considered rude or immature.
