rurouni20xx
ok this is an odd one on me. i have a 92 2.3 2wd ranger, had a bottoming/body roll issue. look at the shocks, they are bottomed/blown and the cheapest gabriels autozoo has to offer. i had redone my brakes/front wheel bearings in the past due to camber issue and the tires had correct camber. i go to autozoo and purchase the gabrial ultras (did wonders on my 4wd 3.0 ranger, stiff but effective). i install them and notice the jack and bumpers seem a little lower than when i started to jack the truck up to install them. figured it was just me and my eyes and went and did the front. crawled under the truck to look at the driveshaft for slack (had just rebuilt the rear end wanted to check the pinion wear) and noticed it was tighter than usual as well. the shocks upon inspection were not blown or busted they are riding where they should be, but i measured and my truck sits 2 inches lower than before...this doesnt bother me but one thing about it does. the body roll at 60mph isnt as bad as before but still noticable, and my front wheels have a negative camber now. id rather not eat up my front tires on the inside, and talked to autozoo and naturally they have never heard of this problem, would taller springs help me out? looking to stiffen the front end anyway to stabilize the truck as i like to corner hard but the camber needs to be fixed for my tires. just wanted to kno if you guys would recommend a leveling coil spring to straighten up the front wheels. thx for all replies.
