englewoodcowboy
- Mar 18, 2013
- Automatic
I have tachometer issues. My 88 ranger tach does not relay engine data. When you turn the key on, the needl moves a little and when you turn it off, it drops a little but it does not read engine rpms. We pulled it out and checked the connections and everything appeared fine and I tested the signal wire from the coil and it is sending signal that my FLuke meter can read. So, how do I know it is the tack? Right now there is one on ebay I can grab but I dont want to buy something if that is not the problem.
Second problem, the horn does not work. You push the center of the wheel and you get nothing, no relay click (if there is one) etc. but the center button feels almost not springy either. I would like to get this fixed by the time my next inspection is due, neither item has worked from the day I bought it and apparently the dealer knew someone who signed off on it. I dont want to use a aftermarket button on the dash if I dont have to but I know parts are limited on availability....
