New motor won't start
00srad600
Scenery hill pa
Ook I have a 89 ford ranger 2.9 I blow them motor like 2 montha ago and just got a motor for it the motor is out of a pre 89 ford ranger 2.9 I swapped all the sensors and wring from mine motor the motor has spark fuel and fuel pressure the mOtor will fire but not when your on the starter you let off and she will make 2 or 3 fires but won't start I'm lost wont fire on starter fluid need the truck like 4 weeks ago
Truck turns over no spark now changed the distributor and coil with MSD still nothing has fuel there is a new modular no blown fuse could it be a relay
Check the grounds, make sure every thing is grounded correctly, ohm them out if needed.
I'm really thinking that it is going to be timing I just pulled my motor to do a flywheel and i broke my cap when I put my wires back on I did it as the bbok said little did i know the po had all the wires off one spot to the right once I moved them to where he had them fired right up. but my motor just beeing that much out did same as what yours is
