lifted4.0
- May 3, 2008
- Age
- 44
- Automatic
heyy guys/gals, soo i put my new built motor in...yadda yadda...with the m112 on it...and the spec stage 5 clutch (i needed the clutch, some said spec was legit..some said they would not goo with spec...at all...some said that they have had some small problems with spec...) soo that was mixed feelings with that..but centreforce didnt have the dual friction clutch for another like 3 weeks..and i HAD to put the motor in...and soo i went to spec and scoped that out and got the stage 5 because the rep told me that it would hold the most torque at 510 at the flywheel...stage 4 was 420...stage 3+ was 370 stage 3 was like 320...and i was planning on putting about 300whp down, which would hopefully be about 360ish wtq...which is somewhere above/around 420..soo to be safe on that i went to stage 5....PROBABLY OVERKILL...i notice that now....
but onto the problem...the setup only has 110miles on it now..soo i guess its kinda hard to judge the problem, but anyway...i ahev to like relearn how to drive cause the clutch is like sooo sticky that WOW...but anyway again
when i left the tuner shop (they tuned the fuel trims to make it driveable) i heard this like chirping noise as if i was breifly spinning the tires...and the tuner was like, waoh i was not hearing that on the dyno...and he thought it was coming from upfront...soo we were guessing the clutch or something to do with the clutch
soo i drive it around blah blah and its just SCREAMING (chirping) but like really whinning and high pitched when i pull from a stop...more soo when i ride the clutch alittle..but i dont think the tranny will be able to really take me just dropping the clutch, and that will be hard on all the joints....but it chirps in 1st...then i shift to second and it slightly chirps..and sometimes it chirped going into 3rd....now after driving it alittle...i started to realized if i try to rev match the shifts and slowly let the clutch out...SLOWLY it wont do it...just coming out of a stop it will...WIERD....but driving today...i went through all the shifts and IT DIDNT DO IT..AT ALL...not even from a stop....
then when i get home, im pulling onto the lawn and its making the chirping sound when my foot is nowhere near the clutch...this also happened when i was breaking while the truck was still in gear...just foot on the break..and it was like chirping....soooo that throw out my thoughts about stuff that had to deal with the truck just starting up or whatever...like the clutch being like too good and the clutch making contact with the flywheel and making a chirp or something? i dk..
anyone have any ideas for me? thanks
