New member
Boga0911
U.S. Military - Active
USA
Hello, new here have a project truck 2001 Ford Ranger XLT with about 72,500 miles. Looking for tips as I go through and make this truck right again.. all work done on my own in my garage…
having a custom front driveshaft built due to the lift, if anyone knows what bolts I need into the front transfer case it would be greatly appreciated!
Welcome! Can't be too much that needs put right with those low of miles.
However.. going back to a factory intake would reward you with more usable power.
Here’s a short this…
Optima yellow top battery
Rear Driveshaft
U-joints front and rear
Rear pinon seal and nut
Rear yoke
Front Driveshaft (custom for lift, pending build)
Front CV axles
CV axle seals
Front pinion seal
Front yoke
Front Hubs
Front brakes and rotors
Rear brakes and drums
Added rear view camera
New stereo w apple car play
Subwoofer
New speakers
New multifunction switch
LED high/low beams
LED rear lights
3rd brake light
Replaced all O2 sensor
MAF sensor
TPS sensor
Cleaned throttle body
Spark plug and wires
Ignition coil
Fixed exhaust leaks
EVAP sensor
Radiator core support
Radiator
Water pump
Serpentine Belt
Idler Pulley
Belt tensioner pulley
Bed lined entire truck and bed
Fuel pump and straps
All new stainless steel brake lines
All wheel studs
Welcome to the site.
Good looking 2001 Ranger!
Consider renewing the 2 TimingTensioners in that V6~4.0L~SOHC,
& swapping in an Aluminum ThermoStatHousing;
both NotoriousFailureItems.
Geez...I got tired just reading the list.
Bedlined in lime green? Hold my beer...
