2WD I assume? And color please. Pics if you got 'em :D
Welcome to TRS.
Welcome to the site.
Welcome to TRS. I'd start with raising the axles and checking the bearings and brakes all around.
That should ensure it will go and stop :D
Good luck with it man
Pics will be forthcoming. Brakes are good, wheels are solid (no shake in any direction when it's off the ground) but does have a shimmy at speed. I'll run it up to my local Discount tire tomorrow, so it might come home with a new set of shoes. It's got a good size crack in the windshield, along with a bullseye type star, so it's getting a new windshield as well. I suspect it needs a tune-up, because 65 is when it runs out of steam. I'll pull the plugs tomorrow and check them out, along with the air filter. Plug wires will be replaced with the tune up.
Welcome to TRS. You've got a good truck. It won't let you down if you don't let it down on maintenance.
I got a new windshield about 3 years ago to replace the original with its small crack in it, and now the new one already has 3 times as much cracking as the original had :/
Nice! And clean. Texas (Ranger) truck
Welcome to the Herd; lots of friendly knowledgable folk in these forums!
