junkfixr
Starting at the beginning, it's an 87 2.9 Ranger, and suddenly fuel economy went from 15/18ish mpg down to 10 or less. I ran it out of gas so I replaced the fuel filter then noticed the tank was rusted out. Replaced the tank and the pump at the same time along with another new filter.
Someone suggested that the cat converter may be clogged so i gutted it and put a new muffler on. Engine ran cooler than before, but i'm still only getting 10 mpg or less, and on it's first road trip today it wouldn't go over 45 mph climbing uphill in traffic.
Another problem is that on cold starts, I have to rev it high and hold it there to burn off excess fuel. I get alot of white smoke,sputters & shakes but after a few minutes of the high revs, it clears up, idles pretty good & starts again without touching the gas pedal.
I'm wondering if I have a stuck open injector that's causing the cold start problem but any thoughts on why such horrible fuel economy & loss of power ? If an injector is stuck open would it burn off after cold start & idle well ? Any thought on the egr valve and whether to block it off or not ?
Kinda at a loss here cause it shifts fine without slipping but just wouldn't climb a simple uphill bridge. When I downshifted it revved like hell but just wouldn't go anywhere. Wondering if I have multiple problems or if I'm overlooking something obvious ? ANY suggestions would be appreciated.
