mrmas
- Oct 24, 2008
- Automatic
Hello All,
I need a little help. Master Cyl went out on my 99 Ranger. Replaced and bleed the brakes twice. New fluid to each wheel and no air. I get brakes until I stomp them one good time and then they go out again. I suspect that the ABS pump is full of air and that is what is causing the problem. When I jam the brakes it is loading the system with air.
Any way to activate the abs system and bleed? Do you think this is the problem?
I may be off base on my synopsis here so any suggestions are welcome.
