johnnybravo234
- Sep 5, 2010
Hello. Mustang enthusiast here now stepping into the realm of 4x4 rangers.
I'm having an issue with vibration in the steering wheel in my 2007 ranger. It starts to pick up after 50 mph but you can feel a slight vibration at lower speeds. It has brand new tires and I had the truck aligned and the tires already rebalanced/rotated without a change. I also personally inspected them for damage. Last night on my way home from work I decided to pull into a parking lot and do some sharp turns to see if I could hear any wheel bearing or other noises from the front end. It seemed like there was some brake scuffing coming from the drivers side front wheel as I made a sharp turns. After that I was pretty set on my diagnosis of a failing wheel bearing although there isn't any grinding/howling under normal driving. This morning I jacked the truck up and couldnt find any play from the 12/6 positions. I then got my prybar out to see if I could find play anywhere else. When I apply pressure to the inner cv shaft that goes into the differential it has a decent amount of slop on both sides. Is this normal? I just bought the truck a couple weeks ago and have a warranty but the dealership is really grimy and is going to give me the "Everything is normal" BS if I don't shove the problem in their faces. I almost want to do the work myself since they will probably install the cheapest parts as possible. Any advice is appreciated.
