the intake on the f-150 5L's are much different... i assume efi?
this is the mustang's (sometimes the label plate is missing, or the wrong plate, note the throttle body compared to the exploder 302) this i should add is NOT in a mustang, this is in a landrover, so the intake tube is in the wrong place, but the throttle body to exhaust looks proper, except the missing EGR spacer between the intake manifold and the throttle body
this is the explorer 302, the 90* corner on this motor is not present on the 5L HO (mustang motor)
and the f-150's this one has been painted black, it's usually the same grey as above
this is a COMPLETELY different motor, but still a ford 302, the 2011+ mustang 5.0 TiVCT motor
the 302 efi was also in the cougars, the thunderbirds, the crown vic's the gran marquis, and i'm sure some other cars, in the 80's and early 90's... they may have different variations on them on top of the ones above, i'm not sure
for future reference, you want to make sure you know which one it's out of, as the 302 HO does not use the same firing order as the rest, it uses the 351W order
