So I just bought my first Ford Ranger. It is a 1993 Ranger Splash with the 4.0 automatic with push button 4x4. It has some sort of lift on it as shown in pictures which I was told is the cause of my camber issue, is there a way to fix this WITHOUT removing the lift?
Patience Padawan...I think I have seen some things on camber and lift on here.. you might check out the suspension subforums.. might be as simple as a new camber kit for a lifted truck. Check out the tech library (top of the page) as well. Until then have a cold one and sit back and shoot the breeze with us
Go to Napa and get some new alignment bushings, I think their biggest is 4 or 4.5* which should take care of most of that issue, you could attempt a DIY alignment with a tape measure, I think there's something on it in the tech library
For
