New guy here, 2.3 crank sensor problem
Journbisc
Hinesville, GA
Got most of the way taking everything all apart, was going to do the timing when I realized the sensor is actually broken. (Hint why it won’t start up?). But my problem is how do I get the dang thing through the timing cover and shove the new one back through? I have it disconnected on both ends but I can’t pull it out or anything. Please help this is my daily driver an I’m currently riding a bike to an from work.
Welcome to TRS :)
You have to loosen rear plastic cover to pull old wires out and put new wires in
10mm bolts I believe
Yes, crank sensor is about the only sensor that can cause a No Start when its not working, so the Big Kahuna of sensors
