New from MS
BadRancher
New here from Mississippi. Just bought a 99 Ranger 3.0 4x4. Unfortunately the 4x4 isn't working. This is my 2nd Ranger. My first was a 2000 2.5 2wd extended cab flare side.
welcome from Northwest MS..
I'm in the Southaven area.
welcome
check out the shift motor, it's probably just worn out. you can replace it or find a manual t-case
welcome
Thanks. I don't know that its the shift motor. Dash is indicating that its shifting into 4x4
does it turn your front drive shaft?
might be a hub issue
I haven't been able to check yet. First chance I had to off road it was yesterday., didn't check all the components. I had advice from the 4wd part of the forum that said it may be a hub issue.
I had an issue goin up a hill but gunned it and finally made it up :icon_bounceblue:
good stuff.
what part of MS are you from?
I'm originally frim Yazoo county, but I live in Byram, which is right outside of Jackson on 55.
