New control module and shift motor.....
Lifted94XLT
Shawnee, KS
... But I still don't have low range. When I put the new shift motor in, I transferrred the brown, blue, and green wires to the new connector, and made sure they are in the correct position. It goin into 4hi (well, the front dshaft is spinnin, I think my hubs are blown) but won't go into 4lo.... I can hear the contorl module click, but no light or shifting of the tcase. Also, is there supposed ot be a light on the dash when in 4hi (other than the 2wd button)?? Thanks.
--Ryan
If the 92 is like my 94, then there is a '4x4' light and a '4x4 Lo' light as well - you have to be in 4x4 before you can switch to 4x4 Lo!! And stopped, and I think in Neutral - don't quote me on the neutral, just try it.
An easy way to check the hubs is, jack up the front, and with the truck Not running, spin the front wheels in both directions. The drive shafts should not spin with the wheels. Now using the jack handle or something similar, turn the drive shaft at each wheel. You should immediately hear hub click in and the wheel turn, spin the wheel the opposite way to disengage. Try each wheel in each direction, and remember, each wheel works independently.
