Captainstubs1
- Aug 6, 2013
Hey everybody I just recently bought a 1989 Bronco 2 and I've been doing some reading about them, talked to some friends, and had my own thoughts. You guys seem to be experts past me in this area so hopefully I can bounce some ideas off ya. 1 motor swap the 2.9l in it now is clean and running so I'll probably leave it unless something bad happens but I'm having a hard time deciding between the 302 or the 351 any tips, tricks, or reasons I should/shouldn't use one of them. 2 the rear and front ends I have the 7.5 inch rear end with the dana 28 front end 3.45 ratios my jeep friend said stick with the 28 or go straight to the dana 44 because the 35 is crappy is that just jeeps etc. and should i find a 8.8 inch rear end to swap out the 7.5 inch in case it helps planning at least a 4" suspension lift. 3 my B2 had the rear tire swing option but doesn't have the swing anymore is it worth putting another one on or should i go roof rack. Also on the shorter list removable doors(just a thought nothing serious yet) removable top/ windows whats easier/ needs less fabricating and any other tips for a new bronco 2 owners? Thanks in advance everybody.
