Need your help again
Backwoods, SC
:icon_confused:I'm trying to change the flywheel on my 2.3. I think I have all the bell housing bolts out, but I can't get the trans to seperate from the engine. I know both the top bolts are out and I've check both sides and believe they're all out. I've tried putting a jack and a block of wood under the oil pan. I've been under that truck shaking, jerking and pulling that trans every which a way but still nothing. What gives.
double check the bolts they should be all the way out, then the only thing holding it togeather should be the lil pins used to guide it so its correct?
