Payitforward
- Sep 6, 2008
- Automatic
Got a rebuilt automatic transmission and converter from the local autoparts store that is tagged that it passed all performance checks at their factory. Put it in and have no front pull in any gear or rear drive. There was some fluid left in the transmission from their testing (don't know how much), I purged the lines and cooler and have added approximately 6 qts to the trans from the filler tube. The book says total C3 capacity is 8 quarts. About 1/2 quart came out the vent tube. Some when adding fluid engine off, some when engine ideling. Followed the book step by step on install. I did not add any fluid directly to the torque converter prior to installing the transmission (it should fill with the trans pump shouldn't it?). Torque converter bolts met up flush with the flywheel as the transmission met up with the block so I feel that the converter is fully seated in the trans. Have run the trans through all gears several times and get no response, have manually moved the gear selector through the gears at the trans, engine running and hear it clicking but no difference. I've run the engine maybe 7-10 minutes total since install, is that long enough to get the torque converter filled, all lines and cooler filled with fluid? I don't have a accurate way to check exact fluid level because the dipstick is from a F-150 not correct one for C-3. I don't want to run it too low or too high on fluid. I'm getting frustrated that we are missing something, ANY Suggestions? I don't want to sell as is get some money out of it when a running truck will sell for more.
It's a 1983 Ranger (small) 2wd C-3 automatic V6 engine
The young man that I'm mentoring is owner of truck and I'm helping him out with labor and tools not to mention garage space to work on his Ranger. Any help is appreciated. We are both getting very frustrated. Search under my log in for other postings regarding this truck and previous transmission questions posted. Thanks in advance. Payitforward
