JoeCanada
So some of you may have assisted me before with my overheating issue this past summer. Long and short of it...took the heads to the machine shop, and they were cracked. It's a 4.0 OHV with over 235,000kms, and evidence of past overheating issues, so I suppose that's really no surprise.
At any rate, the rest of the engine is coming out, I figure if I'm gonna do it, do it right. Now's the time to replace all the seals and whatnot while it's out.
Question is, with these engines in general, after having heads die on them, what does that mean for the block? Should I scrap that too? The cylinder walls don't look cross-hatched anymore, if that makes a difference. And I suppose it's possible the deck is warped, but I haven't had a chance to scrape all the old gasket off to check it with a straightedge.
Also, who's gone with the OE head bolts, and whose used aftermarket bolts (ie. ARP)? Which is better, or does it really matter?
I hate to slap new heads on an old block and have the bottom end fail, thus forcing a do-over, if you know what I mean.
Thanks!
Thanks!
