The_Dealer
Well I found out today that my rear spicer shaft is almost at the end of its slip with 4.5" of lift, and I've been tryn to figure out what to do about replacing it. I didn't really want to drop 250 bucks for a new custom shat. With some searching I found that if u use a 1354 front yoke on the rear of the 1350 u can use a stock explorer shaft. Had the j/y do some measureing for me and it seems like it would work. First off they won't sell me just the flange, so where can I go about getting one. Checked online at some driveline stores and nothing turned up. Second question, when I do find a flange do I need to torque the nut to a certaint ft lbs or is it crank it on down? Don't know if there's a certain preload that it needs to be. Tried to search for that and again found nothing. Thanks guys
