joepackersrock
- May 1, 2010
Well I was hoping to put it off until I got out of school...but the 4.0 is just getting weaker and weaker. This is going to be my first time tearing into an engine so if anybody knows of a good guide that would be extremely helpful.
So I my 4.0 has about 250,000 on it and only gets about 11 or 12 mpg. That may be largely due to the fact that my exhaust manifolds are so rotted out that have the exhaust exits at the y-pipe rather than the tailpipe. That issue will be taken care of following the rebuild. I checked the codes and it was throwing up o2 sensors (obviously) and something about the fuel system being lean at part throttle. When I pulled the plugs half of them were coated with that brownish ash which I hear means the valve guides seals need replacing. Other than that it has just a little bit of that tick from the lifters, but I've never heard one that didnt at this mileage. So what should I be replacing...valves? rods? lifters? How far down should I go?
